Fuel Injection and "Lumpy" cam?'s
Old Mar 30, 2001 | 10:13 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
If I recall correctly, the Lobe Centerline Angle determines how "lumpy" a cam sounds. I notice that TPI & LT1 cams have an LCA of 112 or 114. I'm rebuilding a 95 LT1 to swap in and the specs I'd like to use are 234/242 @.050 and .539/.558 Lift w/ 108 LCA. Will this work if I have the PCM reprogrammed? Any drivability problems like no vacuum, stalling, or no power brakes? Thanks
Old Mar 31, 2001 | 12:18 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Well, it'll work with the PCM reprogrammed, but vacuum will be a problem...This just means that your lead foot will get a work out...Honestly, i'd go with something around 112LSA, that cam doesn't look too streetable to me...But then again, i'm still learning the whole cam thing.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
Old Mar 31, 2001 | 12:38 PM
IROC-Z_85's Avatar
Duration effects the lumpy sound as well, your centerline will be your vacume (with duration) Is this engine a 5.7liter? Thats a hefty cam
Old Mar 31, 2001 | 01:01 PM
drain89's Avatar
It will be a 383. I'm waiting on GM to release the 3.80" crank seperately that's in the HT 383 crate engine. I plan on using the 5.94" PM connecting rods. I'm gonna do extensive work on the heads or use AFR LT4 Heads and a Hydra-Rev Kit. So, I realized that I'll have to have the PCM reprogrammed. I know GM used a cam very similar to this in their LT1 they swapped into their raceshop 91Z. They now sell a factory style roller cam with the same specs (pn 12370847) but it has a 112 LCA. I'd like to go as low as I can on the Lobe Seperation Angle though, so I may see about getting a custom grind that has the same lift and duration. I don't want to cause any driveability problems though.
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
My can is 236/246 .590/.590@.050 on a 110LCA
Lumpy yes, Streetable yes but whats everyones definition of streetable.
Chris
1992 25th Anniv Z28 W/383 Stroker
536 RWHP 569 FT LBS
(chassis dynoed at Ramsies Perf.)
MY SITE HERE
[This message has been edited by TPl383 (edited March 31, 2001).]
Old Mar 31, 2001 | 02:39 PM
drain89's Avatar
Thanks TPI383, you inspire many of us! I'm swapping in the T56 with the LT1 so I don't have to worry about stall converter. I also plan on using Hooker 1 3/4" Full Length Headers and custom 2 1/2 duals (mandrel bent). Which will help with the cam. When I say driveability I mean:
1) Power brakes and other accessories still work.
2) No stalling
3) Not having to give it gas in neutral at red light to prevent from stalling.
Also, what kind of power can I expect with this cam and the the parts I've listed? I plan on using around 10.8-11:1 compression. I expect the motor to make power between 2500 and 65-6700 RPM. Does this sound right?
Thanks for the replies. tHe dRaiN
[This message has been edited by drain89 (edited March 31, 2001).]
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
86Base
Aug 13, 2015 05:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
