383 Stroker
Old Mar 28, 2001 | 08:48 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
383 Stroker
I would like to turn my TPI into a 383 stroker with an after market intake manifold/plenum. Anybody have recommendations on kits, intakes manifolds, heads, cam, pistons, etc. I'll be using the car to race in SCCA. Thanks.
'89 Firebird Formula-
K&N Air Filter, Holley Throttle Body Air Foil, Hotchkis Strut Tower Brace, Hotchkis Panhard Rod, Hotchkis Trailing Arms, Kenny Brown Subframe Connectors, GT Auto Assesories aero wing, steering brace
It's mind over matter. I don't mind because you don't matter.
Old Mar 29, 2001 | 04:55 AM
The ODB's Avatar
Scat crankshaft and rods.
JE pistons.
see signature for camshaft.
ODB
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
* vizit miy homepayge * http://www.geocities.com/trailerparkpage/
Old Mar 30, 2001 | 06:41 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
If your doing the 383 you'll be in Mod class.
At that point why worry?
86 T/A 5.0
93 Civic 1.6L
13.5 @ 100 mph
Old Mar 30, 2001 | 09:37 AM
GlennS87's Avatar
See my sig. below.
Neptune, NJ
White '87- 383 Superram ported and matched to TPIS big mouth intake, Eagle cast crank, 6"eagle forged rods, srp/je forged pistons, LPE 219 cam, ported heads(2"x1.56" ferrea valves), Comp cams pro-magnum 1.6 rr's, double springs, titanium retainers,Hypertech power coil and cap, 4 bolt block, TPIS headers, auto(trans kit,shift kit),Pro Torque 2600 stall converter, k&N filter, 3.07 rear diff., Silver ZR-1 wheels 17x9 and 17X11
Old Mar 31, 2001 | 03:39 PM
irocbob89's Avatar
sig
if i did it again, i would go (i have alot of these parts in my engine)
mini ram
afr 195 ported heads
235 duration cam 560 lift
same short block
or you can e-mail me and ill tell you every thing i did.
89 red iroc-z
386 strocker
ross pistons 10.5.1
eagle h-beam rods
miniram
slp cam 224 230 535 544
1.6rr
edelbrock performers p+p
ford 9', 4.11, 31 spline
baer rear brakes
line lock
all the bolt ons
200 shot on the way
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
