can i run the $99 zz4 cam with the stock valve springs
Old Apr 2, 2001 | 04:24 PM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
this will be in an LB9 engine with ported stock heads...
thanks,
Chris
Old Apr 2, 2001 | 06:15 PM
Scubaguy's Avatar
I wouldn't recommend it, usually the stock
springs can't take the abuse a lumpier cam will put them through, and you may drop a valve!!
Mark
Old Apr 2, 2001 | 06:48 PM
98_1LE's Avatar
I would also suggest replacing the springs/valve seals. Last I checked SDCP had discontinued the take out ZZ4 cams. There is one for sale in the for sale section though by SpankuGTA
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
customblackbird
Aug 15, 2021 10:16 PM
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
