injector size question
Old Oct 22, 2007 | 07:06 PM
jed5161's Avatar
Car: 88 Trans Am GTA
Engine: 383 Lingenfelter/AFR 670 hp
Transmission: 700r4 3500 stall
Axle/Gears: 3.90 9 inch
steping up to 383 cubic inch. got afr 180 cc heads (cnc ported), 11.8:1. Tpis mini ram. .555/.555 lift cam. currently has 24lb injecters. What should i go with? gas mileage isn't an issue jus want lots of power. see alot of guys upwards of 38-45 lb/hr injectors, but mainly in newer series motors.
Old Oct 22, 2007 | 07:49 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: injector size question
Here you go:
http://www.iroczone.com/calcs/injectorsize.htm
Old Oct 24, 2007 | 08:52 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I have a 383 putting out 470 horse and i use 30 pound accel injectors and work perfect. If you plan on putting a power adder like a supercharger or turbo you should go at least 42 pound or higher. But for you application i would go 30.
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
