tpi head nd intake question
Old Oct 23, 2007 | 10:29 AM
custom86notch's Avatar
Car: 88 firebird
Engine: 350CI
Transmission: 5speed
Axle/Gears: 373s
what do u have to do to make a regular style head fit the stock tpi? i have upgraded injectors on my car i have the bigger runners nd throttle body i wanna put in heads nd cam roller rockers but i was told i couldnt fit the intake on the dart heads i wanted to get? what should i get or is thre a way to make them fit
Old Oct 23, 2007 | 01:22 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: tpi head nd intake question
There are 2 TPI bases. One from 85-86 to fit the perimeter bolt valve cover heads. Then 87+ To fit centerbolt style valve covers.
The difference is the two center bolts that hold the intake down. One style the bolts are for strait down. The other is slightly angled. I forget which is which.
Either one of them intake should cover "basic heads" Then eldabrock has one for the vortec style heads.
Old Oct 23, 2007 | 06:47 PM
Car: 88 firebird
Engine: 350CI
Axle/Gears: 373s
thank u there isnt any way to put the other style on?
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
