What size injectors do I use?
Old Oct 24, 2007 | 01:09 PM
Iroc'n 87's Avatar
I am swapping out a 305 tpi for a 360 hp 350 tpi I need to know what size injector I should use. Also the swap is from a 1987 Iroc camaro vin code F.
Old Oct 24, 2007 | 01:51 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Re: What size injectors do I use?
Check an internet fuel injector calculator. If you really expect 360hp at the crank, FI calculators call for 28lb injectors. Stock 350's came with 24lb.
I'm using Ford 30# in my 406.
Old Oct 24, 2007 | 07:39 PM
MdFormula350's Avatar
stock 305 tpi's had 19's
stock 350 tpi's came with 22's
I just put in 24s, I would think you would need close to 28s for that much hp at least around 43 psi fuel pressure.
Old Nov 5, 2007 | 09:43 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Throw in some 30 pound injectors and call it good!
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
