URGENT!!! Fuel pump still running.
Old Apr 19, 2001 | 09:15 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
The fuel pump on my 89 still runs forever after the car shuts off. I unplugged the F/P relay and it still runs. I unplugged all the underhood relays and nothing. There is a hissing sound coming from around the fuel rails and intake base. It even started to turn on when the car has already been off for awhile. All by it's self. Please tell me what could cause this.
89 FORMULA WS6 5.7
Aero Package
Dark Purple Hardtop!
Ram Air II Hood
Z28 Hi-Rise Spoiler
Hypertech Thermomaster
10-BOLT POSI, 3.23 GEARS
700-R4 Automatic
Modified Transmissions
K&N Filter Charger
Modified Mass Air Sensor
Ported & Polished Intake
Accel 8.8 wires and coil
Emissions Delete
Dynomax Exhaust w/Tips
McEwen White Faced Guages
Custom Sound System
Power buldge hood
^^ FOR SALE ^^
Old Apr 19, 2001 | 09:26 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
most likley the fuel pump is grounded out since all the relay does is ground it while priming and while running if the relay was disconnected the ground is in the harness between the tank and the relay
Old Apr 19, 2001 | 09:29 PM
Kevin G's Avatar
Your oil pressure switch could be grounded and causing the fuel pump to run on.. Sounds crazy, but disconnect it and see what happens.
Old Apr 19, 2001 | 09:32 PM
Kevin G's Avatar
I should say on some cars, the oil pressure switch is a backup to run the fuel pump if the relays go bad, it wont keep you stranded. I had this happen to a couple cars i worked on in the past, and the oil pressure switch is to blame.. Pretty wierd actually
Old Apr 20, 2001 | 05:59 PM
I replaced the relay yesterday when it started. I had an extra one around. That did not help. I will check out the pressure switch though. Is it the sender or the sensor one?
Old Apr 21, 2001 | 12:08 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
The one down by the oil filter (switch).
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
