Any Suggestions
Old Apr 22, 2001 | 02:17 PM
ChrisRod'sZ-28's Avatar
Any Suggestions
Any of you guys have any suggestions on what kind of modifications will make an automatic 91, Z-28 run high 14's or low 15's without nitrous?
Old Apr 22, 2001 | 02:35 PM
precision350's Avatar
There are numorous things that you can do like heads, cam, intake, gears, etc. but its all about how much you want to spend.
92 Camaro Z28
350 TPI
Dart Iron Eagle heads
10.5:1 cr
Lunati L54779 cam
52mm throttle body
Ported plenum
Home made AFPR ($2)
1 5/8 shorty headers
Ram air
255 lph Holley fuel pump
2.5 inch TRUE DUAL exhaust (no cats)
Flowmaster mufflers
4.10 gears
700R4 w/2000 stall
100HP nitrous
Best time before any of these mods:
15.1 @ 91.9
Best time after mods:
12.60 @ 108.3
That is at high alt.
5600 feet Morrison, Colorado Bandimere Speedway
Old Apr 22, 2001 | 03:30 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
<font face="Verdana, Arial" size="2">Originally posted by ChrisRod'sZ-28:
Any of you guys have any suggestions on what kind of modifications will make an automatic 91, Z-28 run high 14's or low 15's without nitrous?</font>
You should already be there. If not, all the "simple" and "free" mods should get you there (i.e. K&N Air filter, timing, etc...)
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
--&gt;14.97 @ 94.9 MPH&lt;--
'97 Bonneville SSE
Old Apr 22, 2001 | 09:15 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Do all the free mods then do a full exhaust, torque converter, and drag radials.
I know El Paso is quite high, like 4000 feet above sea level. I use to race at the track there when I lived in Alamogordo, NM. I also use to check out Dyer St once in awhile
But you should be able to hit mid 14s with that setup. I've seen stock LT1s hit mid to low 15s in El Paso, you should do better if you can hook up.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
