Just Dyno'd..the numbers are in
Old Nov 3, 2007 | 03:34 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
216rwhp
261rwtq
This is a 305tpi with headers, three inch exhaust, LT4 cam, Arizona speed and marine runners, edlebrock base, ported plenum, and coolant bypass. There is some other modes but nothing as major as these. So im thinking this is a pretty healthy 305. It pulled all the way up to 4700rpms where the graph shows the power falls off. Btw these are the corrected numbers. If i gave u the uncorrected numbers then it they would be 238rwhp. I forget what the torque rating was for the uncorrected number.
Old Nov 3, 2007 | 05:31 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: Just Dyno'd..the numbers are in
what are the specs on the LT4 cam?
Old Nov 3, 2007 | 06:54 PM
subroc's Avatar
Engine: 355 TPI
Not sure. It was in the car when i bought it. All i was told is it was an LT4 cam. I'll see if i can get the answer from the former owner at some point.
Old Nov 3, 2007 | 07:26 PM
88transam400tpi's Avatar
Car: 88transam/ 86 iroc-z/ 64 corvette
Engine: ta 400ci tpi/ iroc 327 / vette 327
Transmission: ta 5 speed/ iroc 700r4/ vette m-22
Axle/Gears: ta 3:42/ iroc 3:73/ vette 4:11
LT4 HOT cam pn#24502586 279/287; duration at .050" tappet lift (intake/exhaust) is 218/228 1.6 rocker ratio (intake/exhaust) is 525/525. Valve lash is zero/zero and lobe centerline is 112 degrees. with 1.5 rockers. lift is .492/.492
Old Nov 3, 2007 | 07:44 PM
subroc's Avatar
Engine: 355 TPI
Its not the LT4 hot cam. Its just the "regular" LT4 cam.
Old Nov 3, 2007 | 10:39 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Then it would seem that it is PN 12551142
Old Nov 4, 2007 | 05:25 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
not bad for a 305.
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
