tpi 305 mods?
Car: 1988 iroc
Transmission: 700 r4
tpi 305 mods?
so im not looking to make this car run low 9's on the track i just want this car to produce a good ammount of horsepower without having to swap my engine, but everywhere i go i ask questions and of course i get the answer dont bother just drop a 350 in it but i dont want to so what can i do to this motor without blowing it
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: tpi 305 mods?
Quarter Mile Calculator
check out that link and reply back to us with what it would take to get a low 9 second car. by the way with a driver our cars average 3300 lbs.
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: tpi 305 mods?
what would you mean by saying that you want just good enough horsepower. tire squeeeeeeling or sit you in your seat. i mean high flow intake pendulum and runners would help. i decided to keep my 305 as well. i am going to do what i listed with new heads. also like 89305formula has in his sig. descreen the maf and get something like the slp cold air intake with air foil and you'll notice a diff. to start with.
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
Re: tpi 305 mods?
i have a 305 tpi in my camaro its ok.. my mods are under drive pullies.. headers.. 3'' cat back with flomaster...msd coil...#19 svo inj...tb by pass..
ported plem... jet tpi air foil... new trans with stall comverter..and good tune..
will rost tires off no problem.. with 273 gears.. posi.. rear gears next 342... and cam..
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
