NEED INJECTOR ADVICE ASAP!!!!!!!!!!!
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Ok, my car has been running like hell for months and it has finally be traced to bad injectors! I need to order right away... It's an L98 Full bolton car w/Brodix IK200 heads and ZZ4 cam. All mods in sig below. So I think I should def get a little bigger injector. What size and brand do you guys suggest??? Any prices and places to order would be great!!!!! I do have a 406 short block that will be going in this car someday so if anyone thinks what size will work well in both that would be good too! But I'm more interested in a good size for my 350 setup right now?????????? HELP!..lol
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: NEED INJECTOR ADVICE ASAP!!!!!!!!!!!
I ran Bosch 22# Injectors (pink top) on my L98, ZZ4 cam, stock heads, Edelbrock base, SLP runners, Edelbrock TES etc., they made a huge improvement over the stock injectors. If you have more mods to be done, 24# (or larger?) might be better. I got the pink tops from TPiS.
Bill
Bill
Axle/Gears: '01 3.42 10 bolt
i'm running ford blue top 24lb injectors. work great. plan on using them when i swap the upper end to lt1 stuff also.
Car: 89 Formula 350
was just on the phone with Summit
Accel makes 24lb,26lb,30lb....$280
Ford makes 24lb-30lb.....$315
Summit tech was suggesting 30lb but those seemed alittle big??
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
well if you are using the L98 block get the 24lb ones, if you are going to use the 406 engine get the 30lb's. also stay away from accel injectors, you will hate yourself later.
Car: 89 Formula 350
OK guys , thanks.... Just ordered 24lb. Ford Injectors...$249.. $283 over nite delivery from Summit... they matches Jegs price Summit originally wanted $315.xx
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah 315 seems rediculous. those injectors used to be 220-230 dollars a few years back.
92projectcamaro
Jan 18, 2016 08:00 AM
