what's the black film inside plenum, tb, and runners?
Old Apr 25, 2001 | 06:11 PM
irocz_ca's Avatar
first time to remove throttle body and plenum. saw this black film all around the inside of these parts and the runners. wondering what is it before putting them back in. aren't they supposed to be squeaky clean? thanks for info.
Old Apr 25, 2001 | 06:36 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes, clean it.
Old Apr 25, 2001 | 07:21 PM
irocz_ca's Avatar
what would be the best solvent to clean these parts? film seems to be black oily type.
Old Apr 25, 2001 | 07:28 PM
irocz_ca's Avatar
also what causes this film to accumulate inside? hope the causes don't present major problems. the car runs great. i am replacing the egr at this moment why plenum is out. since i bought this car 4 years ago, i replaced the air filters with k&n filters. by the way, i got '89 iroc 5.0 liters tpi 5 speed. thanks again.
Old Apr 25, 2001 | 08:06 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
It's carbon and it's perfectly normal. On higher milage engines the carbon will also have a little oil in it. The carbon gets in there by a process called reversion. If you want to clean the plenum and runners really well, remove them from the car and soak them in mineral spirits. Hot soapy water and a scrub brush works too...but is's more work
Old Apr 26, 2001 | 12:39 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Actually its from your EGR, If you look into your plenum you'll see 2 holes right behind you TB. The EGR gasses are what leaves the carbon behind. Dont even worry about cleaning it, cause 20 miles or so afterward it will be back. Its perfectly normal.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel box & coil, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.23 rear gears, white face gagues, and NOS!
Frozer!!!
Jan 19, 2024 04:55 PM
tazs2000
Jul 15, 2017 08:44 AM
MantyZ28
16
Dec 21, 2015 11:02 AM
tcflint
Sep 14, 2015 04:55 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
