ac delete ?
Old Nov 6, 2007 | 08:57 PM
nightryder's Avatar
ac delete ?
I have a 305tpi im trying to get rid of the ac. do they make a delete idler pully. or a belt for a 305tpi without air? Its my first fbody,sorry for such a dumb ?
Old Nov 7, 2007 | 08:00 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: ac delete ?
They do make A/C delete pulley's... here is one place that has them...
http://www.hawksthirdgenparts.com/in...ROD&ProdID=999
Belts come in different lengths, so if you don't want to use the pulley, you will need to go to your local parts store and get a shorter belt.
You can take a piece of string and route it as you would your new belt. Then measure the length of the string and that should give you a rough estimate of the belt length you need.
Hope this helps!
Old Nov 7, 2007 | 08:21 AM
WillSpeedy's Avatar
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
Re: ac delete ?
search a/c delete pulley at summit.com I think I paid about 19 bucks for mine last year. Works fine looks good.
Old Nov 7, 2007 | 12:16 PM
nomad88z's Avatar
Re: ac delete ?
www.rockauto.com
Look up A/C Bypass Pulley for your application.
If I remember correctly, $24.00 should do the trick.
Old Nov 7, 2007 | 02:18 PM
JustA305's Avatar
Car: 92 Convertible 25th Anniversary z28
Engine: Tune Port Injected 305
Transmission: 700R4 with 2200 stall
Axle/Gears: 3:42 with new posi unit
Re: ac delete ?
Yes they make A/C delete pulley's. I have one on my TPI 305. From GM I bought a 1985 s-10 heater box and kept the heater hooked up and everything.
Old Nov 7, 2007 | 05:13 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
Re: ac delete ?
i have a new ac delete pulley, unused, 30 shipped. pm me if you want it.
Old Nov 7, 2007 | 05:17 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
Re: ac delete ?
just go to the junk yard, u can prolly find one on a non a/c car/truck.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
