TPI Mass air flow to speed density
Old Nov 11, 2007 | 08:04 PM
rsfromhell's Avatar
Car: 89 RS Camaro, 92 RS Camaro
Engine: 2.8 V6, 305 TBI
Transmission: Built 700R4, 700R4
Axle/Gears: 4.10 richmond, Stock
do i need to change my whole wire harness to change from mass air flow to speed density or just the ecm?
Old Nov 11, 2007 | 10:13 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: TPI Mass air flow to speed density
you will have to do some repinning either way. you can't just swap ecm's the connectors at the ecm are totally different. there was an article about it in the tech articles. these can be reached from the home page.
eightsixseven
Dec 16, 2024 01:50 PM
Steve78LT
Feb 24, 2016 12:15 AM
Sanjay
Aug 12, 2015 03:41 PM
86Base
Aug 8, 2015 01:34 PM
