L98 fuel injector removal
Old May 8, 2001 | 11:35 AM
89L98's Avatar
Has anyone with a F Body L98 TPI every removed the fuel injectors with the fuel rails, and gas lines attached without pulling the plenum?
On one of the forums, the person said to just remove the four bolts holding the fuel rail down and you could lift the assembly high enough to see if the injectors were leaking and examine the spray pattern.
Old May 8, 2001 | 01:00 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I've never tried that, but I don't think it'd be all that easy with the plenum in the way. I do know that the injectors can be removed without removing the runners, but I don't quite see your point of wanting to visually watch your injectors fire and get fuel all over...
KAM
Old May 8, 2001 | 01:03 PM
Mo's Avatar
Mo
just pull the plenum, not that big a deal, I left the runners on
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
bryan623
Mar 22, 2021 06:43 PM
NBrehm
Aug 25, 2015 11:49 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
3rdgenparts
Aug 8, 2015 07:09 PM
