Cone air filter on throttle body------>
Old May 9, 2001 | 11:03 AM
gregz28's Avatar
I put the K&N cone filter on my throttle body, gutted my airbox, and took the bellows off but left the airbox lid in place. I know that when the engine is warm, its taking in all that hot air. Have any of you rigged a set up like this? I have several ideas but would like some input.
91 black Z28 305 TPI
Plans for 383...
Jet-coated TES headers, Flowmaster cat-back,
SLP cam (206/212@.050), Cloyes double roller timing chain, TPIS shocks/struts, TPIS STB, adj. fuel press. regulator (47psi), 170 stat, B&M shift kit, BMR 1.5" springs, Ed Wright custom chip, gutted air box, K&N cone filter, Mac Ewen white face overlays
3rdgeners in Europe: CLICK BELOW!
www.fbodyeurope.com
Old May 9, 2001 | 11:52 AM
lb9formula91's Avatar
i have a car with speed density. I just took the air box off and rigged it so that i had a k and n on the end of the plastic arm. I want to get some piping to put in place of the platic. i dont think itll help but i tried
91 formula
305 tpi
borla cat back
white face gauges
home made cold air
tpis airfoil
crane afpr
msd 8.5 mm wires
msd cap and rotor
soon to have ported plenum and intake
We light the tires, so we can fight the fires!
Fighting the "RED DEVIL" on the southside of bethpage!
Old May 9, 2001 | 08:47 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
About the best thing you can do is route some tubing to get fresh cool air. Anytime you are getting air from under the hood, it is going to be much hotter than outside air. There are many ways to do this, one of which is using dryer ducting to pull air from behind the fog light openings (if you have them). This is a good place to do it, because the holes are already there and you will be getting the air before it gets to the radiator or anything like that to heat it up.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
