China Wall oil sensor
Old Nov 20, 2007 | 12:30 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
I got an open oil passage in the back china wall and I forget if a sensor goes there or not. I already have an oil sensor above the oil filter its black with a 3-wire connector. I heard an oil sender or something goes on the china wall also but I don’t remember any sensor being there. Does any sensor go on the china wall for my car? If not where can I get a plug, to plug that hole? Because the machine shop left the china wall oil passage open and plugged the passage above the oil filter. Thanks.
Old Nov 20, 2007 | 12:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: China Wall oil sensor
Just plug it with the pipe plug that you took out of the hole above the oil filter.
Old Nov 20, 2007 | 12:41 PM
Car: 89 GTA
Engine: L98 350
I think its a different size, and the machine shop super glued it in or something I had to drill it out a little with out drilling to the other side of the plug and use an easy out so that plug is ruined.
Old Nov 20, 2007 | 01:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's the same size. They didn't glue it in, they used thread sealer on it as they should have.
Old Nov 28, 2007 | 05:31 PM
Car: 89 GTA
Engine: L98 350
I know they didnt super glue it in they just did a good job. Anyways how tight should the plug be? Becuase it keeps leaking alot of oil.
Old Nov 28, 2007 | 05:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Did you use thread sealer on it?
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
