Map Sensor
Old Nov 23, 2007 | 05:20 PM
b4ccamaro350's Avatar
Car: 1992 B4C 1LE
Map Sensor
I am interested in porting my plenum and getting the slp runners. I've to a 1992 L98 and have heard that doing so will screw with the MAP sensor and the car wont idle right. Does anyone have any info on the matter?
Old Nov 25, 2007 | 01:41 PM
tmviper's Avatar
Re: Map Sensor
i recently bought the tpis indsider hints book from jegs and they discuss map sensor tuning as following: the map sensor is basically an electronic vacuum guage. when you do something to let more air into the engine, the map sensor will not see it, so it will not change amount of fuel going to the engine, causing you to run lean. the way correct this is to A) re-map the computer,via PROM tuning, or B) get an adjustable fuel pressure regulator to manually add more fuel. ive never done something like this to my car, but this is what TPIS says.
Old Nov 25, 2007 | 05:39 PM
Car: 1992 B4C 1LE
Re: Map Sensor
thanks. thats good info.
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
