Which DFI?
Old May 10, 2001 | 10:57 AM
RGS1260's Avatar
Which DFI?
Which DFI is best ?
Which is more user friendly.
Holley,Accel,Felpro?
Old May 10, 2001 | 03:16 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
I don't know anything about the other brands, but I have an Accel and I like it. I find it user friendly.
Old May 13, 2001 | 02:26 AM
89ProchargedROC's Avatar
i have and like DFI but it isn't easy to learn to tune and you can find for relatively cheap nowadays
Fel-pro is much more user friendly with the wide band option...but is expensive
Holley is new and dont know much about it
Old May 14, 2001 | 02:29 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
The Haltech E6GM is pretty user friendly and uses graphical mapping vs. tables. Its easier for me to tune using these graphs vs. a table with a whole bunch of numbers. The Haltech is cheaper (~$650) uses your stock harness and sensors, and includes the software and cables. I had my car on the road in a day starting from scratch.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
efiguy
Sep 27, 2015 01:30 PM
e3pres
Sep 9, 2015 01:51 PM
marcusaw
Aug 10, 2015 08:13 AM
manuel
Aug 19, 2001 10:29 AM
