?'s about L98 Heads( Iron and Alum.),ZZ4 Heads
Old May 15, 2001 | 09:22 PM
The Man's Avatar
what is the difference if any between the L98heads(iron on the Z28) and the Alum L98 heads? Are the combustion chambers the same? intake runner and exhaust? I was looking at some ZZ4 heads, they are the same as the L98 Alum.. right? Does the ZZ4 heads have the right intake bolt angle for a 92 Z28 or will have to grind out the holes?
Old May 16, 2001 | 01:17 AM
Guest
Guest
Posts: n/a
From the top:
Yea, the intake port is a little different, the exhaust port is D shaped and flows alot better.
The combustion chambers are nowhere near the same, the iron heads are 64cc(varies) and the alum. heads are 58cc(varies) with angle plugs and a 'swirl pad' that IMO is useless but there nevertheless.
The ZZ4 heads are the same deal.
The intake bolt angle is the old pre-87 style, so you will have to grind out the holes on your 92 intake. Its not too bad to do.
Old May 16, 2001 | 08:26 AM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
are the zz4 heads emmisions legal??and if so how much for them? and where is a good deal on them?
white/gold GTA ,leather 5.7TPI 700r4 3:27posi twin cats,3"catback,aluminum d.shaft ported plennum,afpr,8mmwires,k&Nand all other "free" mods, performance resource chip,SLP cold air intake.
Old May 16, 2001 | 09:01 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
They dont have EGR passages in them, so they are only legal if you run a Corvette style EGR, which requires a stock Corvette or aftermarket intake manifold.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
lt500r55
Sep 1, 2021 01:30 PM
Chuck84TA
Jul 15, 2016 09:05 PM
gixxer92
Sep 1, 2015 04:32 PM
italiano67
Aug 31, 2015 06:04 PM
theurge
Aug 21, 2015 12:46 PM
