Difference between TBI and TPI serpentine setups...
Are there any differences in the brackets and bolt holes between a TBI serpentine setup and a TPI serpentine of the same year? I have someone who is willing to sell me their serpentine setup, however it was off of an 88 F-body with TBI, and I am retrofitting to a older TPI unit.
If you have done this, what problems did you run into?
Thanks,
Mike Metzler (Desert86Roc)[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For 86 IROC 305 TPI (406 build in progress) Page
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, headers, no NOS)
Thanks,
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Should be the exact same, except some of the braces are different, and are unneeded.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 1987 Z28 Convertible
Transmission: 5-speed
Mike,
I know you've been e-mailing Phil about this one. I swapped a serpentine system from a '92 305 TBI RS. Everything works except one support brace. On the TBI, this brace attaches to the passenger side bracket behind the A/C compressor and the top of the intake (towards the front edge). On the TPI, this brace bolts to the front vertical surface of the TPI base (intake manifold). Fortunately, this brace (#10105292) is still available from Chevy for about $5. The bolt is 8 x 1.25 x 25 (#11508106).
The odd thing is on Phil's '89, he doesn't have this brace. I'll e-mail both of you an exploded illustration. Hope this helps.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig): 12.57 @ 111 mph.
Former Paxton (6-psig) & former 50-hp nitrous: 12.04 @ 114 mph.
Current ATI D1SC (Initially 10-psig): Projecting high 11's.
Future ATI D1SC (15-psig): Gotta catch them pesky 26-psig boosted TTA's!!
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited May 22, 2001).]
Willie
I was wondering if either of you knew the part # or amount to take off a TPI serpentine setup after you remove the smog pump. How many inches do you take off the belt or the part# to the belt.
1989 S10 Blazer 355/700R4
evilstuie
Jan 9, 2020 08:29 PM
Sanjay
Aug 12, 2015 03:41 PM
10105292, ac, altetrnatortpi, brace, bracket, brackets, differences, port, serpentine, setup, tbi, test, tpi, tuned, wiht
