tpi fuel pump doesnt come on when ign is turned on.
Old May 22, 2001 | 06:54 PM
442guy's Avatar
got code 54, its a 85tpi. the pump doesnt come on anymore, used to just come on when engine is cranking after a while, but not anymore. oil pressure switch is good,
the ign wire is good to the computer, pump is good, relay is good, also the green with a white stripe wire from ecm to relay is good,(tells relay to switch) cant get the pump to turn on through the aldl, if i give 12 volts to the relay it comes on. the only cut in the wiring harness, is where th ecm fuse is. there is a orange wire and a black wire coming from the ecm fuse holder, the black then gets spliced into an orange and straight to battery +. any suggestions? how is the ecm fuse supposed to be wired out? hard to troubleshoot the 85, everyone has schematics for 86 and up. dave
Old May 22, 2001 | 07:30 PM
irocrob's Avatar
Car: 1985 Chevrolet Camaro IROC
Try to get your hands on a Mitchell Repair CD from a local garage. I also have an 85 TPI IROC. These are the best that I have found out of all of them. Easy to read, nice diagnostic flow charts, etc, etc. I had an intermittant MAF problem that eluded me for around a year, with this CD from my local garage, the car was fixed within 2 hours.
Rob Kowalski
85 IROC, 305 TPI, JET AFPR - 45 PSI, B&M Megashifter, B&M Shift Kit, 3.42 gears, SLP Airfoil, SLP 1 5/8 headers and cat back system, gutted cat, gutted airbox, MAF screens removed, K&N, more to come!!
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
