found a IROC is it the good one?
Old May 22, 2001 | 12:01 AM
Going Slow Sucks's Avatar
I'm looking at a camaro with a 350tpi, the car has some problems with it. I think i found most of them but, the seller acted funny funny when i reterned from my test drive and inspection. The car has a top end tick, lose ball joints (both sides)and it seeames to get hot. One of the two eletick fans won't go on. I tryed to tap it to see if it might kick in but no luck.The water pump was just replaced. but still runs hot.
A guy I know told me that there might be a problem with a motor mounts.I put the car into R&F (automatic)a number of times to see if the motor would, move or make noise.I did't here anything or see it move too much,but when i looked under the car the front u-joint had rubbed on the top of the trans tunnel.Is there a problem with the 5.7 motor monts.The seller was in the room so I did't put the car under a load while doing this.Is ther a nother way to find out.
Old May 22, 2001 | 03:16 AM
IROC KID's Avatar
Walk away,i warn you unless you have deep pockets or a generous girlfriend to help you pay all the repairs and parts that need to be replaced,how much does he want?what is the body and interior like?
www.rearman.com/camarokid.htm
If it aint a V-8 that $hit aint fast!,unless its a GN,lol!
305 tpi,700r-4 with shift kit,My mods are minimal,just a bunch of little $hit.Anyone know where to get underdrive pulleys for a v-belt set up?
Old May 22, 2001 | 07:21 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Chances are its the tranny mount that is broken. A replacement fan motor can be had at autozone, DAP or napa cheaper than the dealership. Like 30 bucks or so. If you don't have a good feeling about the car I'd step away and find one you do have a good feeling about.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old May 22, 2001 | 04:02 PM
87iroczmd's Avatar
only one fan is supposed to be on unless the car is operating above 220* or so, i thought i had a problem when only one fan was turning but it is normal, if the transmission mount is broken, when you floor it you will hear the transmission jump
Old May 22, 2001 | 04:11 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
throw the ac on the second fan will turn on that ticking you hear up high may be a rod if it were a rocker or valve chances are you would hear it at part throttle as well
Old May 22, 2001 | 09:09 PM
mjdoyle's Avatar
I just wired my second fan directly into the first so both are always on now...
Gotta keep that puppy cool
NinjaNife
Aug 23, 2015 11:49 AM
ChevyZ71
Aug 13, 2015 07:30 AM
bjpotter
Aug 12, 2015 06:06 PM
mustangman65_79
Aug 11, 2015 03:17 PM
antares57
Aug 6, 2015 07:47 AM
