Corvette TPI on a Camaro
Old Dec 6, 2007 | 01:26 PM
ccook-92-305's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R4 w/transgo 700 shift kit
Axle/Gears: 3.42 posi
Ive done a lot of searching and I havnt found a straight answer to this yet, but maybe im just missing it. I know the corvette TPI is the old style intake and the fuel rails are a little different; but point blank will it work on a camaro? If i bought an entire kit, computer, wiring harness, plenum, tubes, throttle body, all of it, can I make it work on my camaro? And if it does work how serious is the surgery that is required? Thanks for the help!
Old Dec 6, 2007 | 01:31 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: Corvette TPI on a Camaro
you can make anything work, the EGR is different on a corvette setup and the fuel lines i believe are in the front of the intake, you'll have to make up custom fuel lines, if your bypassing the EGR it should not be a problem
Old Dec 6, 2007 | 01:33 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Fuel lines on the fuel rails wont mate to F-body fuel lines
Vette draws EGR gas from a tube on the exhaust manifold that goes to the back of the manifold (unless it is a 85-early87)
I think the harness would be pretty hard to adapt
Your better off waiting for f-body stuff that matches your car perfectly
Old Dec 6, 2007 | 02:10 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Ok, thanks for the help. Ill probably just look for one of a camaro.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
