heated O2 sensor.........
Old May 30, 2001 | 08:42 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
i need to get one for my car. who is the best for the money? So far i have seen one from TPIS and MSD. The MSD one is $80 which is way too much for me. Anyone know of one for around $40 maybe??? thanks for the help.
Old May 30, 2001 | 08:54 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i have a bosch 3 wire in my bird i think it was $43 from auto zone
Old May 31, 2001 | 12:40 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
do you know the part number? how did you splice it into your system?
Old May 31, 2001 | 01:07 AM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I used an AC Delco one.
Part # AFS-74
This was the cheapest heated one I found at the time.
To hook it up is simple. The purple wire is the signal that goes to the wire you have now. The other two wires are tan. These you hook to ground and +12 IGN.
Mark.
Old Jun 1, 2001 | 12:21 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
thanks man.
Old Jun 1, 2001 | 12:44 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Should you opt for the heated one if planning to replace it. I have a 89 MAF TPI. Can I use it?
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
