Does this seem right??
Old May 29, 2001 | 05:23 PM
IROC5.7TPI's Avatar
I was surprised a few weeks ago when my car went a 13.98 @ 100mph on a g-tech.
Look at the sig for mods. In addition, I have every possible option you could get on the car. I took the spare/jack out (for other reasons).
Also I weigh close to 300 #'s and that should slow it down some too.
What do you guys think? Should I be going faster?
Mike L.
"If it feels good - stay in it "
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, Relocated MAT sensor, Gutted MAF, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, airfoil, Random Tech Hi-Flow Converter (soon to go byebye!). ALL STOCK otherwise.
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old Jun 1, 2001 | 02:13 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Breaking into the 13 sound pretty good for all that you have done, esp since you did not alter the cam or heads. You would probalbly see a lot better times with a steeper gear, esp since you got that converter. The car would really spool up fast and launch hard with a 3.73 or 4.10. Just have to remember that the mpg goes down as the gear gets steeper.
As comparison, my bird is only running low 15's.
Michael Graeber
My Garage
1)83 Z-28 T-Top: Full cage, 9" w/ lad.bars, Midwest Engine Tech 406sbc,Strip Dominator, 1000-CFM Demon Carb, Phase VI Chevy Bowtie Heads 2.05/1.60, .630" Crower roller set-up, 1 3/4 coated Hookers 3" true dual exhaust th400, fuel cell & still not running
2)89 Formula WS-6 305 TPI Auto Daily Driver: minor motor mods, more suspension stuff. MODS
[This message has been edited by graebz28 (edited June 01, 2001).]
