Can I use Motorsport 24lb injectors in my T/A?
Old May 31, 2001 | 10:34 AM
jfulford's Avatar
I have an 89 T/A with a 305. I have just had an 89 GTA 350 rebuilt for the car. I currently have 19lb injectors. I have heard of using the 24lb injectors from ford in these setups. Will this work and do I lose/gain anything by not using GM specific injectors?
thanx
jeff
jfulford1@earthlink.net
Old May 31, 2001 | 11:09 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Several of us (me included) use FMS 24# injectors. I'd suggest that you tweak your prom to take advantage of them though. Visit the DIY-PROM board for more help.
Old May 31, 2001 | 11:30 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
is this a just a .30 over rebuild?or are you like stroking ot out to an 383?if it's going to be a pretty much stock rebuild the 24lbs injectors my be too much.i've heard people have had alot of luck with the 19lbs injectors on 350's.
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old May 31, 2001 | 11:57 AM
jfulford's Avatar
Thanx for the reply. Engine specs:
-355 with Keith Black pistons
-Stage II Summit rods
-Stock 1989 Roller cam, with 1.6 rockers.
-Stock L98 heads with stainless valves/Ported.
-52mm BBk TB
-Modified MAF
-Custom Chip
-410 gears
-Edelbrock Headers/3" exhaust/hiflow cat
-140hp Nitrous
Could I get by on 19lb injectors? I thought at least 22's.
jeff
Old May 31, 2001 | 01:10 PM
evilho7810's Avatar
The ford injectors work perfectly in our cars but our injectors will not work in mustangs for some reason?
Old May 31, 2001 | 01:21 PM
91-ZZ4-Z28's Avatar
They both use "Bosh" style injectors that are interchangable with about 80% of cars on the road. The 24# will be just fin for a 355.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,and just about every other bolt on that there is. Just got a ZEX nitrous kit!
Old May 31, 2001 | 06:51 PM
Kyle F's Avatar
You cant run the 19lbs or you will be toast with that NOS. I had a similar set up without NOS and 305 heads that had just mild work on them. The mother ran lean as hell, but I knew if I put 24#ers in I would be rich as hell I really needed the 22#ers, but I had plans of NOS on mine and New that once I put the AFR heads and the 150hp shot I would need the injectors.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Jun 1, 2001 | 07:49 AM
91banditt2's Avatar
Engine: 5.7 HSR
ok so you've added NOS to the mix!!yeah go with 22lbs injectors at the least
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
