TPI in need of help
Old Dec 16, 2007 | 05:12 PM
Irocvirrilli's Avatar
TPI in need of help
I have an 89 IROC with tpi and a t-5. Recently had a fuel pump installed and now the car bogs down at wide open throttle, popped the hood to check it out and i don't have a maf, crazy i know but the car just runs in open loop now. Also, the car has two fuel pumps, one in the engine bay thats aftermarket from the TPI swap and then the new 50 psi pump in the tank. Would to much fuel pressure cause the car to bog down or is it like an ecm malfunction or TPS problem, i will try to set the TPS at .54 today if it's not already there, but any suggestions will help, i'm looking for a maf core so i can buy a rebuilt one, if anyone has an extra on here i will gladly purchase it thanks much
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
