oil leak... help
Old Jun 6, 2001 | 06:53 PM
mjdoyle's Avatar
oil leak... help
OK.. i have an oil leak that i originally thought was the drivers side valve cover gasket.. from underneath the oil appears to be running from the rear of the gasket... well i just pulled the valve cover and the gasket looked clean... could the leak be coming from the oil pressure sender unit or distributor??? how do i find out i cant see a thing back there...
Mike
88 Iroc-Z 350 tpi, Hedmann Headers, 3" Cat Back, MSD Ignition, K&N, AirFoil
Old Jun 8, 2001 | 04:03 PM
camarocowboy's Avatar
One suggestion,if your dip stick is driver's side like mine,could be coming from there.Also pull your distributor up and check the gasket,could be worn and if it is coming from the sending unit you should be able to tell after the distributor is pulled.
Old Jun 9, 2001 | 03:49 PM
Tonyrodz's Avatar
Transmission: auto
I had the same problem, it was coming from my oil sender. Car was idling for awhile and there was a nice little puddle when I moved. I looked under the hood and saw it dripping from the sender. Let me know how you make out.
Old Jun 9, 2001 | 11:55 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
go ahead and replace your sending unit. alot of times when they go bad they start leaking. just use some teflon tape on the threads and that will probably fix it.
good luck,
Dan
87 IROC-Z, 5.7,auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, Accel .219 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon- DFI or prom burner, Dart Iron Eagle 200cc heads, 6" rod 383 or a 406
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
