I need base sensor paramaters
Old Jun 7, 2001 | 06:17 PM
bowtiez's Avatar
Hey, just got my Auto xray scanner and found it does not come with factory parameters. Need source for my 85 z28 305 tpi. Hope someone can help. Are there any sources for all makes and models, factory sensor parameters? Just in case a friends car needs help.
Bill
Old Jun 10, 2001 | 01:22 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
You might be worrying about something you don't need to. When you punch in the Year/Make/Model and Vin Digit, your X-Ray knows what sensors you have and what the parameters of these sensors should be.
Your X-Ray basically does nothing but read sensors that your car has and reports it's findings. A bad sensor out of range will usually throw a trouble code and the x-ray will know this.
At any rate a good aftermarket shop manual or factory manual along with this board will get you through any question or situation that arises.
racereese
Oct 10, 2015 09:39 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
85 Jimmy
Sep 30, 2015 07:56 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Randomtask2
Sep 10, 2015 08:37 AM
