can't start with out pressing gas
Old Jun 9, 2001 | 02:26 PM
Going Slow Sucks's Avatar
just bought my 88 IROC-z and it has trouble starting.IT turns over fine but it wount fire unless I pump the gas.The car is stock.
Can anyone help, i don't have a scan tool?
It idles rough for the first min or two.once it up at running temp it runs fine. Shut the car down and try to restart same thing but no rough idle.
88 Camaro IROC-Z
350TPI
[This message has been edited by Going Slow Sucks (edited June 11, 2001).]
Old Jun 9, 2001 | 11:20 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Could be IAC or maybe TPS? COuld be gunnk built up in the TB housing too, and in the IAC passages.
Does it idle fine once started?
Old Jun 10, 2001 | 02:47 AM
88IROCs's Avatar
One of my IROCs started doing that last summer,... little did I know that the fuel pump was not long for this world(there is no worse feeling than deccelerating while going down a steep hill with your fooot on the loud pedal). Hasn't done this since the pump was replaced. Sounded the same then as it does now('bout 2 seconds of whirring when the key is moved to ON. Didn't set any codes before it went either(set a bunch of them when it quit tho).
Old Jun 12, 2001 | 01:53 PM
jmon92conv's Avatar
I have the same problem with my Camaro. Check and clean all the sensor connections and the positive battery cable. This usually helps for a while (a few months0 and I have to do it again. I haven't been able to narrow it down, but I think it is in a fuse link on the positive battery cable.
Jeremy
WE WILL MISS YOU #3
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's, Edelbrock STB, 350 in the works
Old Jun 12, 2001 | 09:04 PM
mjdoyle's Avatar
I have the same problem.... I ran a tank of 94 octane and the car started beautifully every time... went back to 89 octane and same thing... it will turn over but without a little pedal no go.. unless you turn it over for about 20 secs.
I dont know if running the 94 was coincidence or not.... I am going to try running another tank of 94 to see what happens and if it starts again i will know it is not coincidence... The only problem is I dont want to buy 94 octane all the time..
Can anyone explain this?????
Old Jun 13, 2001 | 01:34 AM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
I dont know about that 94 Octane thing. For me, it was the exact opposite. I ALWAYS ran 93 octane or higher....for years....then, recently, i tried 89 octane, and the car seems to act, respond and start a whole lot better and easier. I dont know...sometimes i think my TA came from the Twilight Zone....
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old Jun 15, 2001 | 11:44 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
In reality it sounds more like he's not getting enough air..
When you start it, if you open to WOT (by hand at the TB), and "let it go" does it backfire on its way down??
You can disconnect the TPS and start it BTW..
It will idle w/out it..
-- Joe
92camaroJoe
Jul 29, 2023 07:57 PM
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
