TPI Distributor Cover
Old Jan 5, 2008 | 07:56 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Quick question.
What are the dimensions of the Distributor cover bolts.
I bought a cover, but no screws could be found.
Anyone know the length, diameter and thread and whatever else is nessecary?
Thanks.
Old Jan 6, 2008 | 09:14 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: TPI Distributor Cover
The aluminum TPI plenum extension's screw are different in size than the plastic one.
You can get the correct screws from any GM dealership or Hawks Third Gen also have them....
Old Jan 6, 2008 | 12:44 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
actually, they have the same threads, just different size heads. the aluminum ones have a smaller recess for the heads of the screws.
Old Jan 6, 2008 | 01:47 PM
MP81's Avatar
Car: 2007 Cobalt LT
Axle/Gears: Stock
I have a plastic cover.
Old Apr 19, 2008 | 09:58 AM
Vader's Avatar
The thread is M4 x 0.7. The original screws were 13mm long, had a button head with a T20 recess, and included a special shouldered SEMS washer. You should be able to use any M4 0.7 from 10-15mm and a standard flat washer.
Good luck finding those at places like Homo Depot. You'll need to find a REAL hardware store or specialty distributor like Fastenal.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
