Help w/ part numbers...
Car: 91 Z28
Engine: 5.7
could someone direct me to a link that has GM part numbers... or if not I not the part numbers for a new egr and o2 sensor - my friend told me to use the GNX O2 sensor since it has a bigger filiment I didn't know if this was a good idea or not... thanks!
91 z28 lb9 5 speed - hooker 1 5/8 headers - high flow cat- full 3 inch exhaust - home made ram air - tpis airfoil - dual chamber flowmaster - Stage 2 Jet Chip and 160 stat - 8 mm Msd plug wires - 55,000 v hypertech coil/rotor/distrib. cap - Mac. White face gauges - lots of sound system crap...
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I was talking to the guy at the parts store the other day, and he CLAIMED, that all single wire O2 sensors were the same, and they give the same one to EVERYONE. He is more than likely wrong, but go to a store and find out. Ask the nice man behind the desk to check some part numbers for you...
just a thought.
87 Formula Yellow/Black
Engine & Transmission
.040 over 5.0 converted to TPI, 9.5:1 Compression, SLP Cam Dur 206/212, Lift 480/487, Cent Line 112, SLP headers, SLP cat-back exhaust, K&N Airfilter, Modified Stock cold air intake, Ported & polished Stock TPI intake, Holley Adjustable Fuel Press regulator, AC Rapidfire Spark Plugs.
Gil Younger (no yo-yo) Shift Kit, Aluminum Driveshaft, 3.73 Posi gear
Suspension & Brakes:
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Hotchkis strut tower brace, South side machine frame connectors, Custom reinforced control arms and pan hard bar.
Interior:
Custom Leather interior, CUSTOM Yellow Gauge Faces, Kenwood Receiver, Pioneer Speakers, Kicker Substations, Kenwood 10 Disk Changer, Pioneer Amp.
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
just a thought.
Interior:
83 Camaro (Parts)
83 T/A (parts)
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
GM parts manual on-line
http://www.metzcon.com/fbodymanual/
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
86 Camaro Sport
My Camaro Project
Car: 91 Z28
Engine: 5.7
THANK YOU!!!
Car: 91 Z28
Engine: 5.7
oh and the GNX o2 sensor is different since I've seen it - GM only made it for the GNX - My best friend put on in his grand national and it actually made a difference over the stock one - the stock one wasn't old either he had just replaced about 2 months before but heard the GNX one was way better from the other GN guys...
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
