__engine pics__
Old Jul 4, 2001 | 09:15 PM
thickfacek's Avatar
__engine pics__
Wanna see what yall have done to your engine. Post pics
> 1990 IROC-Z (black)
> one of 3000 IROCs with a 305 made in 1990
> flowmaster exhaust
system with mufler bypass
> z-28 spoiler
> blue under car neon kit
> check out my site at: http://geocities.com/thickfacek/IROC-Z.html
> email me at thickfacek@nc.rr.com
Old Jul 4, 2001 | 09:22 PM
Jas89TTA's Avatar
Click on the link in my Signature to see my Engine Pic. Later, Jason
350 TPI, 5-spd, 3.73 gears, Posi-Rear, LT4 Hotcam, 1.6 Roller Tip Rockers, Accel Intake, Ported SLP Runners, Ported Stock Plenum, Ported Cast Iron L98 Heads, Coated Hooker Headers, 52mm Edelbrock Throttle Body, 24# SVO Injectors, SLP Cold Air Intake, Holley AFPR, LS1 Aluminum Driveshaft, Flowmaster Exhaust, Taylor Wires, MSD Coil,
Engine pic at http://albums.photopoint.com/j/Album...410&a=13413975
Old Jul 5, 2001 | 01:39 AM
SCFORMULA1's Avatar
Scott's
89 formula 305TPI
ASCD Ram-Air Hood, Neon light in Scoops of hood. custom carbon fiber Ram-Air Box, K&N Air Filter,manley street flow valves, port and polish heads, LT4 hot cam, crane chromemoly push rods, crane hydraulic roller lifters, 1.6 roller rockers, comp cams timing chain, edelbrock water pump, SLP intake - ported and polished, Adjustable fuel regulator, Power Pulleys, custom burn chip, Edelbrock Headers, Hi-Flow Cat, Flowmaster, Accell Supercoil, Taylor Wires , B&M Shift kit w/ Corvette Servo, exhaust dump, Auburn Pro-Series Posi-Trac rear end with 3.73 gears, Kenwood 6-disc Changer, 2 600-watt Kenwood 12" subwoofers , 600 watt Kenwood Amp, Racing Stripes, Blackouts, Alarm System, Chrome GM 5-star wheels off of 98' Formula with custom carbon fiber WS6 center caps.
Old Jul 5, 2001 | 11:07 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
Pics location are in sig.
http://www.havemann.com/lee/firebird.html
1989 Firebird Formula, WS6 Package
ZZ4 Crate engine, Accel 24 pound injectors, Accel Superram intake, Accel Large tube runners
SLP 58 mm throttlebody, Edelbrock TES headers, SLP 3" SS exhaust, Random Tech 3" hi flow cat
700R4 trans w/ vette 2/4 shift servo, worked valve body, kevlar band, 2200 rpm stall converter
Borg Warner 9 bolt rear (full poly mounts) Hotchiss panhard rod, Lakewood LCA's, Spohn subframe connectors, custom chip.
