TPI fuel pump in a TBI car?
Old Jul 6, 2001 | 10:01 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Want to switch from TBI to TPI...so I will be getting a new Walbro High-Pressure
255 ltr/hr pump.....however...About a year ago I got a flowmaster exhaust installed at a muffler shop...and they welded everything....I was thinking of taking my car to a shop...and have them do the fuel pump swap....so they can weld the exhaust back together..and i wont have to deal with it...first..it shouldnt be THAT much money in labor should it? Second...will my TBI system beable to handle the new fuel pump....it'll only be temporary (from the shop back to my house)....I am a bit confused because I know TBI uses like 12psi fuel pressure...and TPI around 40 or so...but will the TBI regulator do its job and take it all the way down? Thanks for the info. Also...any recommendations as to where I should take it? Should pretty much any shop beable to do it? Should I be there and watch and make sure they do everything right?
http://users.ticnet.com/mult68
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cat Coming
More to come.
[This message has been edited by mult68 (edited July 06, 2001).]
Old Jul 7, 2001 | 03:03 AM
Dan87IROC-Z's Avatar
With the cost of the new pump, it was over $500 for the new one to be installed in my car. But then again, I never really found out how much of that was the cost of the pump, or how much of it was the labor, so it could be pretty costly. I think to get to the fuel pump inside the tank, you have to drop the rear end, the tank, take appart the tank and install the new pump, quite a bit of work, so it could be 4 or 5 hours worth ($240 - $300) in labor alone. I do think that the FRP should slow the fuel down enough that you wouldn't be running at an unsafe fuel pressure.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Jul 7, 2001 | 03:07 AM
mult68's Avatar
Engine: 305 TBI
Man....well i guess I'll have to do it my da*n self....oh well...my only problem is having to cut my exhaust....guess theres no way around that....unless I take it to the muffler shop...have them cut it off and store it for me......drive home...do the swap...then drive back and have them put it back on.....hmmmmmm..........i shall see.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
