Removing the GTA air filter canister 'Rain Guard' - Safe or Worth it?
Old Jul 12, 2001 | 11:23 AM
Night Hawk's Avatar
I've cut out large squares out of my 1988 GTA's air filter canister and put on a K&N air filter and I've noticed an slight improvement and I'm wondering if it is safe or benefitable to remove the black molded plastic 'rain gaurd' to the left of the air filter canister? Is it worth the trouble or will the motor just inhale hotter air and actually hurt performance?
Old Jul 12, 2001 | 01:34 PM
86Trans Am's Avatar
I AM NOT SURE WHAT YOUR AIR INTAKE IS LIKE, but on my 86, it had a steel canister with a square plasitc lid, ON MY setup, your not supposed to cut holes in the canister because the filter filters air from the inside out. ON MY set up the only thing you should cut is the lid, and even then there is barely enough room to make a difference. I got rid of the whole system and made one from 3" pvc and a clamp on k&n. The mass-airflow sensor is rounted in there also.
Old Jul 12, 2001 | 03:53 PM
breathment's Avatar
this may not be wut u are talking about, but on my GTA, i have a open K&N filter attached the the black intake hose with basicaly nothing surrounding it, its open on all sides, and i have driven through some tuff rain with no problem. But then again they may not be wut your talking about.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Jul 12, 2001 | 04:06 PM
rondubbs's Avatar
i thihk that piece of plastic is there as a heat shield... (if we are talking about the same piece)..
take it off if you want,, i dont see how that prevents rain from going anywhere, the hood does that
Old Jul 12, 2001 | 06:15 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
the piece he is talking bout looks like a bell on the canister all it does is streamline the air coming from behind the passenger headlight you most likly wont see anything from it i would reccomen going to home depot getting a 28in. peice of 3in. pvc pipe(paint it to your liking and attach a k&n directly to the end of the pvc with the k&n filter sticking through the pass. fender slightly.
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ads strip chip,relocated iat sensor,tb bypass,hollowed maf,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
slp catback tomorrow(7/13)ed wright's fastchip saturday!!!!
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Zachattack0925
Aug 12, 2015 09:52 PM
