2000 to spend on mods, what should i get?? HELP!
Ok i used to have a 91 RS but i recently sold it and found i can spend 2000 on my new car. I bought a 91 Z-28, its only got 83000 miles on it and its an auto. It is supposed to have a 305 but i was told it has a 350 block now but im not sure. All it has is flowmasters and kn filters. What should i get with this money? I don't know much about TPI engines and was hoping to find some help.
My advise is first find out if it IS a 350 or not.
Then i would say since you have $2000 right now to spend, buy the big stuff, then you can do the little things to catch up.
Go with a set of trick flow heads.
Then port your stock base, and put on some SLP runners. Then later put in a cam and your heads/intake will REALLY shine.
If you decide you just want to do smaller things, get a mini or a super ram. That will be most of your money
1985 IROC-Z
TPI 305, 700R4 with shift kit, richmond 3.73's, auburn pro series posi, crane compucam 2030, ported plenum, gutted air boxes, all the little insignificant stuff.
1985 IROC-Z
Oh yea...
SD
If you do heads, you're REALLY going to need a PROM.. and it will have to be custom.
So i'd say visit the DIY PROM board and get ready to burn your own.
1985 IROC-Z
SD
1985 IROC-Z
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
forget about heads spend your money where it will be worth something get a shift kit for the tranny,a set of 3.42 gears(recommend getting a whole rear=cheaper than having someone install gears),and a "vigillante" tourqe converter,precision industries guarentees at least 1/2 second drop in e.t's.get yourdrivetrain in order before rippinginto the engine should get you low 14's on a stock l98-Z.good luck
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete.
oh!no!i think my maf is going!!!!!!!!!!!!
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
kammi10
Nov 9, 2015 08:28 PM
HoosierinWA
Oct 7, 2015 10:15 AM
