carb to tpi swap
Old Feb 8, 2008 | 02:33 PM
J_Dubb44's Avatar
Car: 1984 Pontiac Trans Am
carb to tpi swap
i have an 84 TA with a carbureted 350 and a complete tpi system from an 86 TA. Exactly how difficult is it to do this swap? And should everything bolt right up to my TA?
Old Feb 9, 2008 | 02:06 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: carb to tpi swap
The hardest part is dropping the fuel tank and installing the high pressure fuel pump. Otherwise, if you know how to swap an intake manifold and modify a wire harness, its pretty straight forward. Definitely not for a beginner though. Get someone to help you and photograph everything.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
