86 iroc, 355 swap and heads to cam
Old Feb 9, 2008 | 02:33 PM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
ok I have a 1986 Iroc Z with a 305, Im tired of it not being enough so I have a fresh 355ci with 10mi on rebuild I have these heads
14102193...87-up...305/350......1.94"/1.5" valves
Im wondering if I can put my intake onto these heads, If not what heads will work with my TPI intake?
Also does anyone know what kind of cam and how much I can go with this set up? I want a rough idle cam but nothing to the point I cant drive on the street.
Old Feb 10, 2008 | 09:10 AM
Car: 86 Iroc-Z
Re: 86 iroc, 355 swap and heads to cam
no one has any ideas for a good set up with heads and a cam??? What about The LT1 head swap?
Old Feb 10, 2008 | 09:45 AM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
i think you can mod the 4 center holes to work on the heads you have or get a 87 and up tpi intake.. do you have a roller block. im building a 91 350 4 bolt roller block with 083 heads... and a hot cam i thike for my set up i have a ramjet 350 cam to..
Old Feb 11, 2008 | 07:49 AM
Car: 86 Iroc-Z
Alright cool thanks, IDK what I have all i know is its a hydralic cam, Havent torn it apart to find out yet. I was reading up on the lt1 heads, Think thats a good idea? I mean Do I have to run the LT1 cam or can I go with this cam
http://store.summitracing.com/partde...2&autoview=sku
I know I will have to go with the LT1 intake which is fine, All I know is I have to get it machined for the distributer. Am I wrong? I wanna know a good cheap set up if anyone knows of one.
I know My block is good for 400+ but 500 is pushing it on a 2blt main I just wanna be able to make atleast 450hp
Old Feb 11, 2008 | 08:28 AM
400 hp's Avatar
Car: 86 z28
Transmission: th350
Axle/Gears: 7.5 342
what year is your block.. you can run lt1 heads with tpi to.. with mods. to them... roller cams make more power. so you might want a roller cam to that kind of power...
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
mustangman65_79
Aug 11, 2015 03:17 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
