TPI or Carb
Old Feb 19, 2008 | 05:21 PM
MrBill85T/A's Avatar
Car: 85 T/A
Transmission: 700R
TPI or Carb
I own a 85 T/A with a 305 TPI and 700R 3:23 I am building a 350 roller block to replace the 305.
The car will be my DD so I'm not shooting for big HP numbers, I would be happy with around 300 at the flywheel.
The TPI seems to be very expensive to improve and it looks easier to install a intake and carb.
I do love the look of the TPI and the great starts and drive ability.
If I use the TPI research shows that I should upgrade to the 86 and up computer which means a harness change and a lot of work, 22lbs injectors, and maybe a custom chip.
I'm open for suggestions
Old Feb 19, 2008 | 10:41 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI or Carb
If its already TPI and a daily driver, then keep it TPI. Carbs are for race cars, EFI is for street cars.
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
