corvette lt1 camshaft
Old Feb 29, 2008 | 04:23 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
whats the difference between it and a regular lt1 cam. Ive read my 305tpi will like the lt1 , could I use a corvette lt1 cam in it? thanks.
Old Feb 29, 2008 | 06:31 PM
Damon's Avatar
Re: corvette lt1 camshaft
I don't believe there was any difference. Year for year, same as the F-body LT1 cam.
Old Feb 29, 2008 | 06:42 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Not sure if you meant same pattern, dur, and sep. or just they both physically fit in my sbc?
Old Feb 29, 2008 | 08:13 PM
Damon's Avatar
I mean same specs.
The LT1 cam differed in specs slightly from year to year, but within a given year I beleive the specs are the same between LT1 F-body motors and LT1 Vette motors.
The Vette had better flowing exhaust, dual knock sensors, different oil pan and a better air filter/intake system, but was internally all the same specs as the F-body LT1 within any given model year.
In the 98-up LS1 motors GM originally intended to remedy this situation (the F-bodies being too close in performance to the Vette) by giving the F-body motors a milder cam than the Vette, but that didn't happen. Even LS1 F-body motors share their cam with the top-dog Vette.
Old Mar 3, 2008 | 09:45 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Your 305 would like the B-body (Caprice, Roadmaster, Fleetwood, ImpalaSS) LT1 cam even better. It has tighter lobe separation, better IVC event, and makes more midrange torque than the F/Y LT1 cams in the 350 motors. I'm still running this cam in my 4000 lb ImpalaSS and running mid 12's on motor only.
88SS6SPEED
Nov 11, 2015 07:05 AM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
sahlomonic
Sep 20, 2015 07:15 PM
