Help me get the best perfomance parts for the least money
Old Aug 20, 2001 | 12:14 PM
89IROCZZ4's Avatar
Here are my main specs on my car zz4 w/stock tpi, 2.73 gears and 1850 stall. Other mods include headers, flowmaster, chip, k&n, etc.
Okay...I was told several things by several people on what to do: So far I think the thing I am definately do is get 3.42 gears.
Now, for the intake: Do I port the whole stock system? How much could I expect to pay and how much would it pay off?
What about ltr's and big mouth manifold? Together they are $950!!! Is this worth all the money over porting just what I have now stock? I want mid 12's at least (I currently run 13.30 @ 106), and I would like to get there the cheapest way possible. :0) Should I just go carb then? If so, THEN what do I get?
Old Aug 21, 2001 | 12:02 AM
Iroc n roll's Avatar
As far as the intake goes you'd probably be better off getting a new one. The isn't all that much room for porting on the stocker, although I have heard that theres a guy on here that will make it flow like a big mouth manifold. If your really serious about track times the miniram is the best bet in my opinion. I think going carb is like taking a step backwards, but i could be wrong. With bigger gears and a bigger torque converter (closer to 3000RPM stall) the miniram should give you excellent performance. Alot of people say that you'll lose torque with the MR, but if you search the boards for some threads by TRAXION you'll get all the info you need. BTW you'll want better heads first before you get the MR or it won't do you much good. Are you running stock heads?
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
--Cullan Hooley
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, 3" CatCo Cat, Rebuilt TH700R4 with Shift kit, 2,800RPM Torque Converter, 3.73 Richmond gears, Auburn differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to Andris Skulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, and more to come.
Old Aug 21, 2001 | 08:23 AM
91-ZZ4-Z28's Avatar
The gears and converter are a very good idea. You can get an edelbrock manifold and port it for cheaper than the big mouth (it is a ported edelbrock TPIS grinds off the name). I have SLP runners and they are cheap but only get them if you have a fair amount of porting experience because you have to port them to make the same power as the AS&M or TPIS. Also check out items for sale on this site and on ebay you can find grate prices sometimes. The miniram and superram systems are great but you said for the least money and they will cost you.
1991 Z28 ZZ4 with LPE superram base, SLP runners, LPE 58mm T-body,Random Technology ramair,TES headers,24#svo injectors,ZEX nitrous,Walbro 255lph f-pump,Accel AFPR,Random Technology catback,!cats,and mutch more.
Jake_92RS
Jan 28, 2020 10:37 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
