i own a 1988 350tpi iroc its completely stock except for the computer chip and the accel supercoil and plugs and wires and a k&n . i was wondering what is the factory size of the fuel injectors and what size should i get? i am planning on replacin them with accell fuel injectors out of camaro performers magazine .i was also wonderin if anyone has had any problems with them?and has anyone tried the front end kit from the back of the book i am plannin on gettin that too .
Unless you want to start burning your own chips you do not want to change your injector size, especially considering you are all stock. A much better option would be to send your stockers to rich @ www.cruzinperformace.com . For around $100 he will clean and flow match your injectors within closer tolerances than any injectors you can buy, which will be worth more to you than any injector size upgrade.
As for teh front end kit, w/o knowing the brand, etc there isn't much to tell you. You'll be better off asking about this on the suspension board.
...ed
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
...ed
You do not need to up[grade to bigger injectors without having serious mods.The "if some is good ,more is better "doesnt work on this.Hell im running 19# SVO injectors at 52 PSI.Car ET's awful with street tires and terrible 60's ,but by my MPH im not hurtin for fuel.Last time i cked i was around .870 on WOT o2
86 z28 zz4 ssm lift bars ,3.73 simesed runners and a traction deficient 13.707@101.02,on a 2.16 60 ft on 295/50/15 junk street rubber ,best MPH run 13.82@102.7,69 AMX,390 4 speed sticky tires and other stuff..12.94@102.3
