Timing Question
Old Mar 10, 2008 | 09:47 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Timing Question
My car usually runs on 93. If I were to go to the strip and put 110 in her, would I have to adjust the timing, or could I just leave it the way it is?
Old Mar 10, 2008 | 10:01 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: Timing Question
My TPI runs like a DOG off of 110, I'de avoid it. It's nice if you're spraying and don't want detonation but other than that it really provides no help.
Old Mar 11, 2008 | 10:56 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Timing Question
If your running a higher compression engine, I heard that the higher octane will help you and not hurt
Old Mar 11, 2008 | 01:34 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Timing Question
110 octane here in WI has lead in it. Your 02 sensor will get coated and contaminated with lead.
Old Mar 11, 2008 | 02:08 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Timing Question
Higher compression does require higher oct for detonation.
More timing requires higher oct to prevent detonation.
However, there becomes a point where there is just to much compression or timing and it hurts more then helps.
Lower octane is actually more explosive.. it just doesnt prevent detonation like the others do.
If your not pinging on 93, 110 will do you no good.
Old Mar 12, 2008 | 01:15 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Timing Question
The higher the octane the slower the burn.
Think about "fast burn heads"
The faster the burn, the faster the power.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
