*Head Question*
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
*Head Question*
I have a set of heads that have had the pushrod slots elongated to accept 1.6 roller rockers... however, I have 1.52 roller rockers! Question is ... can I use these 1.52 roller rockers with no problems? The heads do NOT have guide plates and the rockers are NOT self-aligning! The slots have only been elongated .... not widened! Thanks in advance!
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.7:1 Compression, Stock TPI ported, 24#/hr LTI injectors (cleaned and flowmatched), Hedman Shorty Headers, 3" cat back exhaust with flowmater, SBC 993 heads completely redone and modified for 1.6 RR, Comp Cams XE262-14 TPI Cam, Ed Wright Fast Chip, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Box, Hypertech hot coil!!
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Yes, you can use the 1.52 ratio rockers with no problems.
1988 Formula 5L/5sp 3.45 gears, SLP cold air kit, MAS gutted, TPIS air foil, TPIS AFPR, MAC headers, Mac under drive pulleys, MAC cat back, Relocated MAT.
Best ET street tires 13.85
Best 60 FT street tires 1.930
Best MPH street tires 99.29
