Nitto Drag Radials
Old Sep 2, 2001 | 08:02 PM
88 IROC BOB's Avatar
Nitto Drag Radials
What's the lowest pressure that can be run on these at the track? Does lower pressure really help alot?
I used to be able to get out of the hole good on street tires and stock convertor.
Now with a PI 2800 stall and new intake I have a hard time hooking up on the Nitto's.
So far I've aired them down to about 25 psi but still had trouble. How low can I go and will it help alot?
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Sep 3, 2001 | 12:46 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
I know it's not directly related, but with the BFG drag radials you can go as low as 12 psi.
I hope to try my GForce DR's next weekend.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Sep 5, 2001 | 10:43 PM
redhottlb9's Avatar
I have Bridgestone Potenza RE910's on my car..regular street tires and I had mine down to 18psi when I ran,so I really dont see you having a problem going as low as 12psi
Andy
The "House" has spoken...
check out my my 88 WS6 Trans Am
We are the seeds of legends,our true origins are unknown...WE SIMPLY ARE...
Old Sep 6, 2001 | 10:28 PM
98_1LE's Avatar
I have done some tests by doing a small burnouts at different pressures and examining the black mark. My 245/50/16's on stock 16x8 wheels left the best marks at 24 psi, and thats where they seem to hook the best. Anymore I run 24-26 psi all the time. The sidewalls are a little loose but the tires wear more evenly and *** help those that try me from a stoplight
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old Sep 6, 2001 | 10:42 PM
Am I to assume that you also run Nitto's.
Bob
Old Sep 6, 2001 | 11:22 PM
91'firebrd's Avatar
Don't have Nitto's but with ET Steets, I got the best traction with about 22-24 psi. At 18 psi I noticed the inside of the skid mark was getting light.
Thats with tube type tires so with Drag Radials I can't see going any lower then 18 psi. I know a couple of cars at my track that run on Drag Radials (BFG's not Nitto's) and they use 20 psi.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
JSDaddy189
Sep 26, 2015 03:50 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
fasteddi
Sep 10, 2015 09:32 AM
