Speedometer question
Old Mar 23, 2008 | 08:50 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
Ok I have a 92 maro... Obviously I have the electronic speedometer. I picked up an 89' TPI setup, MAF of course... I was wondering how I am going to get my speedometer to work with the older computer and stuff?
Old Mar 23, 2008 | 09:33 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: Speedometer question
Depends on what you have now. How is the T56 setup? You have TBI right now?
Old Mar 24, 2008 | 12:29 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
I have tbi and 700r4 right now... TPI is almost done... Need hydraulics for t56
Old Mar 24, 2008 | 06:10 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
well then for right now, you have it easy.
Just run the wires that go from the buffer box into the TBI ecm, into the new MAF TPI ecm. done.
The speedometer works off the buffer box, so you don't have to mess with it at all.
Old Mar 25, 2008 | 04:38 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
Im no expert but I started a post for my swap, my car is a 91 camaro TBI auto and a member here told me that I have the 4000ppm signal and the 89 ecm uses the 2000ppm. My swap is the 91 TBI to 89 TPI.
Is the 92 different for the vss buffer box?
Old Mar 25, 2008 | 11:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
All TBI's run the signal from the 4000 pulse VSS into a buffer box and then 2000 pulses to the speedo and 2000 pulses to the ECM.
Or you could convert to 90-92 speed density and run the VSS straight to the computer. Much better in my opinion.
Frozer!!!
Jan 19, 2024 04:55 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
