Taking off fuel injectors???
Old Sep 9, 2001 | 09:12 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
I'm taking off my fuel injectors to send out to get cleaned and matched. Do I need to take off the runners to get the injectors off the fuel rails??? Also, if I have to take off the fuel rails entirely, how do I take off those metal lines from the fuel rails? Also any advice in this process would be helpful. Thanks.
1988 GTA (36,000 original miles):
Crane Cam, K&N
Flowmaster, Off Road Pipe, NOS,
MAC underdrive pullies
Tuned by Motorsport Depot (402)274-3831.
1/4...12.90s at 112mph
Old Sep 9, 2001 | 10:08 PM
JR4444's Avatar
I recently put on bigger injectors and Yes you have to remove the Runners. I didn't take off the fuel rail I just got it loose enough to pull up the injectors. If you want to pull it off remove the lines in the back first to let all the preasure out.
Old Sep 9, 2001 | 10:09 PM
Vader's Avatar
GTA,
The steel fuel lines are not designed to be removed, so the rails and lines need to come off as an assembly. There is a plate at the front of the engine that serves as a junction point, where the rubber fuel hoses attach to the steel lines. Remove the connections there and remove the mounting bolts in the plate, then you can remove the rails and lines as an assembly.
Later,
Vader
"Click - Click - BOOM!"
Adobe Acrobat Reader
Old Sep 9, 2001 | 11:05 PM
GTAlover's Avatar
Car: 1986 Camaro
Axle/Gears: 4.10
Thanks for the help.
Crane Cam, K&N
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
