INTANK or EXTERNAl Fuel Pump
Old Sep 12, 2001 | 08:48 PM
STUB25's Avatar
I just wanted to know which is going to be easier to a complish. Either a external tank fuel pump or intank? Let me know what you recomend as far as fuel pump to go with as well.
STUB25
Old Sep 13, 2001 | 10:53 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
If your car came with a factor intank pump, then that would be the preferred choice. Otherwise an external on the frame works. External is a pain in the sense you have to plumb the lines and connect power, etc.
The intake is more likely quieter than the external.
Mark.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
