I need a new fuel pump, help?
Old Sep 19, 2001 | 01:13 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I've done a search and found that the Walbro unit is the most recommended. (255 liters/hr)
However, I cant get a Walbro for a few days.
I can get an updated turbo Transam fuel pump for $133 in two hours and have it installed tomorrow. Yes, I'm in a hurry.
Does anyone know what the flow rates are for the fuel pump in my 350 TPI (that I have) and the '89 turbo transam?
I need maybe about 10 to 20% more flow rate.
Will the turbo Transam pump be enough for me?
My stock fuel pump can not keep up with my fuel requirements (or it is slowly dieing).
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 3000 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, 24#/hr SVO injectors, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(50psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.27sec @ 103mph on MT ET Streets
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
Old Sep 19, 2001 | 01:56 PM
JucinGTA's Avatar
Did your pump fail? I would actually put a second one in, its very easy, or if yours did fail, put a normal intank one in and a normal second inline one.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
